5/1 .5 Made cut line to prepare to remove wing 5/2 3 -Removed wing -Rearranged garage -Cut out right wing ailerons and started working on aileron spar 5/3 3 Made aileron spars Started hinge install 5/5 1.5 Finished hinge install Made aileron counter balance brackets Made one aileron control arm 5/7 1 Floxed nut plates to spars Worked on lower wing root fillets 5/8 1 Floxed in one aileron spar and worked on more fillets 5/9 1 Glassed wing side aileron spar Glassed lower wing fillet 5/15 4 Floxed aileron spar Glassed spar Clearanced for counterweight
