5/3 1.5 marked and cut out template for aft deck 5/4 1.5 sanded and added third coat of varnish to rear fuselage 5/6 1.5 made rear template and started cutting foam for aft deck 5/7 2.5 almost finished cutting and gluing foam planks 5/8 4 rough sanded aft deck to shape 5/27 1 made forward and aft deck foam bulkheads per plans 6/2 1 glued foam bulkheads and sanded to contour. Started fitting canopy.
