Brief Description: finished controls and started stub wings
3/16 3 finished elevator controls Started cutting seat to clear pushrod 3/17 1 started drawing out instrument panel and clearanced outer stub wing airfoil templates 3/18 2 coating canopy with dipcoat to protect during construction and glued both inner airfoil templates to spar 3/21 .5 test fit rear alternator brackets 3/22 1 glued outboard airfoil templates 3/23 1 sanded templates and starting cutting foam 3/24 2 installed rear alternator kit on engine. Bent and cut tubing for pitot/static 3/26 cut ribs for wing walk area
