2/4 1.5 drilled brackets and mounted control stick. Fabricated left aileron cable 2/5 1.2 finished right aileron cable and drilled/mounted pulley brackets 2/6 3 made spacers for aileron bellcranks and started fabricating elevator bellcrank bracket 2/7 3 finished cutting elevator bell crank. Made control arm for elevator on control stick 2/8 1.5 started making rudder pedals 2/9 1.5 worked on figuring out geometry for brake pedals
