Christophers Web Site
Date:  12-27-2015
Number of Hours:  5.00
Brief Description:  Aileron bell cranks and control stick mounts
I fabricated the control stick mounts using 1/4" nylon blocks and aluminum angle. It took me three tries with the nylon but I am happy with the result.
I deburred and primed all of the aileron control horn parts. I ended up swapping the lower brackets from left to right so I could place them higher up to fit inside the new airfoil contour. They were then drilled and bolted to the rear spar attachment fittings.
