Christophers Web Site
Date:  12-25-2015
Number of Hours:  1.00
Brief Description:  Elevator trim tab
I cut out the trim tab for the elevator. I made it 3x7 instead of the 4x10 per the plans after seeing what other people have done. I also cut out the area where the Ray Allen servo will be installed. I cut out four blocks from scrap spruce and will flox them in as mounting points when the temperature gets higher here
