Trevors Zenith CH750 CruZer
RV-7A
Rear Spar Assembly
-Radiused corners and edges on HS-609PP
-Clecoed and match drilled HS-609PP to HS-603PP rear spar
-Clecoed and match drilled HS-412PP and HS-413PP hinge brackets to rear spar
-assembled and match drilled VA-146 bearing assembly
CH750 CruZer Home
RV-7A Home
128
Inspiration
Planning
Practice Kit
