Cowboy's RV-10
Date:  7-24-2012
Number of Hours:  1.50
Manual Reference:  22-8
Brief Description:  Rivet R-Flap TE; Press brass bushing into Flap Hin
22-8:
Step 12: Rivet TE using every 10th rivet rule and a random pattern in between. Took essentially three passes to get rivets flush to underside skin. Couple of minor dents but not noticeable underneath. Nothing a little filler and paint won't fix.
Step 13: Press L and R brass bushing into Flap Hinge attach points on wings. Used a drill bit with some 220 sand paper on it to lightly remove primer from inside hinge points so bushing would press fit in.
Top TE came out well.
Pressing bushings.
Pressing bushings.
Centered bushing in middle of bracket.
