21-7: Step 5: Same procedure as the L-aileron only that my skill level had improved and results during riveting were better. Did not goof and mark the underside of TE with rivet set. Some proudness next to rivets as observed with the L-Aileron. But again not very noticeable unless in light reflecttion. They did seem slightly higher than the left that I associate with using a little more Proseal than on the left which gave me a better bond on the TE tips than on the left side.Still not decided if I like the Proseal on the TE or not but will continue to use it on the Flaps.
No damage on R-Aileron
A little more pronounced edge around rivets than left side.
