Brief Description: Finish riveting the RightWing LE wing assembly
17-3: Step 14: Finish riveting the Right Wing LE wing assembly. Riveted the last forward rivets with the LE assembly in the cradle vice standing on end. I moved the LE beyond the end to accomodate the rivet gun and hung end over edge of table. Results were not as good. Had three bad rivets on the outer bottom of right wing LE on wing tip side. Tried them a couple of time over after redrilling. Finally gave up and had another expert assist with installing three NAS 1097AD 3-3.5 replacements. Gotta be a two man team doing these last rivets.
