Cowboy's RV-10
Date:  1-19-2011
Number of Hours:  0.50
Manual Reference:  15-4
Brief Description:  Dimpled L & R Rear Spar Upper Flange
15-4;
Step 3: Final drilled #40 and dimpled the 26 inboard most holes on the upper flange of the W-1007A-L and R Rear Spars. Used the pneumatic squeezer. Used the Tatco hand squeezer to dimple the holese in the ribs lower aft tab ond the corresponding holes in the W-1007A-L and R spars. Both seem to work ok. The hand squeezer fit the spar flange easier but either seem acceptable.
