Cowboy's RV-10
Date:  12-29-2010
Number of Hours:  2.50
Manual Reference:  14-4
Brief Description:  Enlarge Pilot Holes for Conduit
14-4:
Step 1: Enlarge forward tooling holes in L-ribs to accommodate Van's corrugated conduit. Used a Erwin unibit, #9 and cut to 13/16 in. This was not a tight fit with the conduit but was enough to prevent it from slipping easily. I will use an adhesive of some sort to anchor the conduit once it is in place for good.
Step 2: Enlarge wire run tooling holes and add additional holes in similar position in upper portion of ribs, both left and right. Additional holes are for future growth or to keep antenna leads separate from other wiring in the event I mount them in wing tips.
