Brief Description: Right Spar - Drilling J-Stiffeners
13-2: Step 7: Clamped the J-Stiffeners ot the spar flanges allowing a 1/16 inch overlap as diirected. Step 8: Match-drilled J-Stiffeners with #40 bit, skipping the three areas noted where not to drill. These areas correspond to the inspection panels on the lower wing skin which have different whole spacing than what willl be needed for the J-Stiffeners. These stiffeners are only match drilled here on the spare but will be places further aft to stiffen the upper and lower aft wing skins. I presume the rest of the holes on the lower J-Stiffeners get match drilled with the skins when installed.
