Cowboy's RV-10
Date: 1-16-2010
Number of Hours: 9.70
Manual Reference: 10-17, 18, 19, 20
Brief Description: Rivet Bellcrank, Batt Mount, Bulkheads, Bottom Sif
10-17: Step 4: Rivet Elevator Bellcrank Assy Step 5: Rivet nutplates on Battery / Bellcrank Mount Step 6: Rivet Battery Channels to Battery Tray
10-18: Step 1: Rivet F-1012A & B Bulkheads Step 2: Rivet F-1011 Bulkhead Step 3: Rivet nutplates to F1011E Rudder Cable Angle.
10-19: Step 1: Rivet nutplates to F-824B Cover Plates Step 2: Rivet F-1010 Bulkhead. Step 3: Rivte F-1008 Frames. Step 4: Install -7 snap bushing in F-1085 Rudder Cable Brackets. Step 5: Rivet F-1007 Frames. Step 6: Install -7 snap bushings in F-1007. Step 7:Rivet F-1006D Bulkhead to F-1006A & C
10-20: Step 1: Cleco bottom Skin, Stiffeners, and Bulkheads / Frames. Step 2: Rivet Stiffeners to Bottom Skin. I elected to back rivet everything I could using a 4" x 16" plate which seemed to work pretty well. Although structually sound, initial shop-heads from the backriveting were not the prettiest but they got better with some practice. But I had a particularly difficult time with the bottom left stiffener F-1047F-L. I had a hard time getting the rivets to pull down straight. I ended up drilling out and replacing 7 rivets on this one stiffener.
DISCOVERY: the left stiffener was not F-1047F-L, it was F-1047B-L (top stiffener). Well, that explained it. Now, all I had to do was drill out about 50 rivets and put the correct one in place and re-rivet. That mistake took about an hour and a half to fix. I spent some time cleaning up and re-dimpling some of the rivet holes on F-1047B-L so it would be ready later (first major screw-up)
Battery Tray
F-1011 rivets turned out well
Bottom Skin Riveted - fixed
