Cowboy's RV-10
Date:  2-12-2010
Number of Hours:  3.00
Manual Reference:  11-6
Brief Description:  Elevator Stop Adjust & Pushrod Assembly Built
Step 2: I used one of the two pushrod end bearings to install, determine spacers needed, and elevator stop adjustment. It required one AN960-10 and -10L per side to take up the slack. Bolted in and snug tight. Down elevator travel required approx 0.3 deg further adjustment only on the left elevator horn. Now a dead accurate 30 deg up / 25 deg down when against the stops.
Step 3: Cut and drilled Pushrod tube to 73 inches and match-drilled the assembly with #32 drill bit (one end by hand and the other end on the drill press). Finished reamed with #30. Deburred, cleaned, scuffed. Pushed a clean rag with acetone on it down the middle of the tube to clean and remove drill residue.
Cutting Pushrod Tube to length
These are ready for primer
These prevent blood on the floor
