Brief Description: Drill Hz Stab Fwd Spar and Spacers to Tailcone
Step 1: Cut wood block as spacer to hold Hz Stab in position when measuring and drilling. Step 2: Square Hz Stab with tailcone using long seamstress tape. Alignment took a slight clockwise twist (2.5 mm our of alignment measured at aft spanwise position). Step 3: Final-Drilled with #12 bit (12 in long). Plans called for Match-Drilling with 3/16 in bit but all I had was short bit. I had great results with the long #12 when I built a temp drilling jig with taylor built wood blocks. This worked well too. Holes nice and straight and bolts fit snug.
