Brief Description: Drilling and Deburring Battery / Bellcrank Mount
Step 6: Separate Battery Channel parts Step 7: Final-Drill Battery Channels, used drill press on 1/4" holes and hand-held on the others. Step 8: Final-Drill Battery / Bellcrank Mount per the plans. Deburred hole, finnished edges, and scotch-brited surfaces.
I may modify the battery tray later to fit an alternate battery such as Odyssey PC925 as other builders have done. For now, these parts are ready for primer.
