Brief Description: Debur & Scotchbrite Stiffeners & Skins, Fit Static
10-14: Step 3: Drilled hole for static source for both Side Skins to 1/2 inch per Cleavland Static Ports. Back drilled three #40 holes for mounting Static Ports.
10-15: Step 4: Debur & Scotchbrite Stiffeners & Skins and rolled lower edge of Left Skin. I used the Cleaveland Edge Forming Tool that has a vice grips handle. Worked great.
