Cowboy's RV-10
Date:  12-12-2009
Number of Hours:  5.10
Manual Reference:  10-1, 13, 14, 15,
Brief Description:  Drilling Aft Deck, Disassemble Tail Cone
10-13
Step 1: Inspect manufactured Hz Stab Attachment Bar Support Angle.
Step 2: Inspect manufactured Up Elevator Stop.
Step 3: Match-drill four holes of F-1010A Spacer.
Step 4: Match-drill side holes of Aft Deck.
Step 5: Final-drill F-1011B Stop/Doubler holes.
Step 6: Position and clamp Attachment Bar Support Angle to Attachment Bars.
Step 7: Position and clamp Up Elevator Stop on Aft Deck.
10-14
Step 1: Remove top Top skins and related Stiffeners.
Step 2: Position and clamp Shoulder Harness Anchors to Longerons.
Step 3: Skipped, awaiting Cleavland Static Ports.
Step 4: Final-drill F-824B Cover Platess to Side Skins.
Step 5: Final-drill nutplate attachment rivet holes in Side Skins.
10-15
Step 1: Mark triangular portion on the forward end of right Side Skin.
Step 2: Disassemble remainder of Tail Cone.
Step 3: Trim triangular portion of right Side Skin.
Step 4: Begin Deburring: completed edges of Bottom, Right and Left Skins.
10-1
Step 1: Tap Tie Down Bar 3/8 x 16 x 1 1/4 deep.
Disassembled
Disassembled
