Brief Description: Drill Rudder Stop, Cleco Bulkhead and Bellcrank Ri
10-8 Step 7: Level Tail Cone and ensure there is no twist fore and aft. Drill Rudder Stop Brace
10-9 Step 1: Cleco F-1006 Bulkhead and final drill bulkhead to bellcrang ribs Step 2: Cleco Baggage Bulkhead Channel to Bellcrank Ribs and final-drill top holes Step 3: Separate Bellcrank Rib Angle Step 4: Final-drill nutplate rivet hole and countersink holes. Got one CS hole on end of one a little deep but should not be an issue it only holds nutplate. Step 5: Final drill Bellcrank Rib Angles w/ 3/16" as indicated.
