Cowboy's RV-10
Date:  5-24-2009
Number of Hours:  3.00
Manual Reference:  9-16 thru 9-19
Brief Description:  Elevator Trim Tabs
- Trim Tabs were assembled with clekos.
- The trailing edge bend was completed using an adjustable hand seamer (Brown Tool BAT-HS01). The edge was gradually brought to final shape using multiple passes back and forth using the hand seamer. This seamer allowed adjustment such that a consistent squeeze could be applied throughout the length of the Trim Tab. Was careful not to over form the Trim Tab such that a concave effect resulted in the Trim Skin.
- Glued foam Trim Tab Ribs into position and reassembled Tabs.
- Clamped and fitted trim tab hinge.
- Rivet Trim Tab Skin
- Match drilled the Trim Tab Hinge with Elevator
- Rivet hinge halves to elevator.
- Assemble and fit check hinges.
Class complete. What a great class.
End of Class, time to go home.
