22-8: Steps 4-8: Prosealed L-Flap TE per the directions in the plans. Used a little more Proseal which I basically wiped and squeezed out the excess. Proved to be a little messier but should be fine. Noticed inboard side of Flap did not lay down as square as I thought the right one did so weighted down that side some more to pull it flush with the table top. Not sure it will make any difference but time will tell how it all lines up when going together, rigging, and flight test.
Tightened down for curing.
TE all pretty much looked the same as this; pulled down fine.
Weighted down the inbd side to help pull it near flush with the table.
