Cowboy's RV-10
Date:  7-19-2012
Number of Hours:  4.30
Manual Reference:  22-7/8
Brief Description:  Rivet L-Flap Skins to Spar; Rivet Top Skin to Ribs
22-7:
Step4/5: Riveted L-Flap Skins to Spar and Top Skin to Ribs per instructions. Adjusted rivet lengths for skins to spar from 3-3.5 to 3-4 as length was better. End tab rivets I squeezed 3-5s as they set better with a more acceptable shop head. The rest of the rivets remained as specified in the plans.
22-8:
Step 1/2: Back riveted top skin last two rivets to ribs. Riveted bottom skins and nose skins to spar. Overlap seams pulled down tight as desired.
Bottom skin seam
Bottom skin seam
Tab rivet 3-4.5 shown here. I drilled it and sqeezed a 3-5..
A flap is developing ...
