Brief Description: Fit Check L-Tank Assy and begin Dimpling
18-4: Step 8: I had done some additional L-Tank Rib Flange straightening and hole alignment after my work on the R-Tank so refit the ribs and AftTank Baffle for fit. Aft baffle flange appeared to have relaxed slightly from a more 90 deg angle prior to dimpling the flanges so used a couple of straight pieces of particle board and clamp to reset the angle best I could. Refit the Aft Baffle and then disassembled the L-Tank. Began dimpling L-Tank Skin.
