Brief Description: Assembled R Wing LE Assy to R-Wing Spar
17-4: Step 1: Enlarged tie-down hole on Right Wing LE Assy to 1/2 inch using unabit drill bit. Step 2: Final drilled the #30 holes common to the main spar assyembly and the aft flange of the ribs in the LE Assy. Assembled R Wing LE Assy to R-Wing Spar.
