Cowboy's RV-10
Date:  7-3-2011
Number of Hours:  4.50
Manual Reference:  16-3, 16-4
Brief Description:  Rivet Top Right Wing Skins
16-3:
Step 3: Rivet top right wing skin outer then inner. Used 3-4 rivets for countersunk wing walk area instead of 3-3.5. Need to build bucking bar to rive 5 forward inboard rivets.
16-4:
Step 1, 2, 3 Riveted outboard aileron hinge bracket assembly on left and right wings per the plans with the exception o using 4-5.5 instead off the 4-6 rive callout. the sixes were a bit too long and bucked better.
3.5 hrs and turned out great!
R-Wing Aileron Hinge
L-Wing Aileron Hinge Shop Heads
