Cowboy's RV-10
Date:  2-13-2011
Manual Reference:  16-3
Brief Description:  Reassemble Left Wing for Rivetting
16-3:
Step 1: Placed wing with forward face against table and blocked up the spar as necessary to ensure straightness. Used fishing line along the front and back of the spar to ensure true.
Step 2: Assembled all the various J-stiffeners, wing walks, and skins in position and clecoed as required. Rechecked true spar lines. Need to see if I can check for twist, although there is not much torsional regidity until I get the bottom skin on. Just want to be sure I don't build in a twist that would bind/stress top skin when bottom skin is put in place.
Left Wing Ready to Rivet
Check for Straightness
Set Jig in Position to Anchor Wing
