Cowboy's RV-10
Date:  1-16-2011
Number of Hours:  2.30
Manual Reference:  15-2/15-3
Brief Description:  Assemble Aileron Brackets, press Brngs, Rivet Assy
15-2:
Step 5: Pressi Aileron Bearings into Aileron Hinge Bracket Assemblies in vice as indicated in instructions.
Step 6:Reassemble Aileron Bracket Assemblies and check that bearings are centered and not spreading the assembly due to mis-alignment. Adjusted as necessary.
Step 7: Rivet Alieron Bracket assemblies as indicated
15-3:
Step 1: Mark W-1007D Rear Spar Doubler Plates as indicated.
