Cowboy's RV-10
Date:  1-9-2011
Number of Hours:  3.30
Manual Reference:  14-3
Brief Description:  Rivet Flap Hinges and Torque Tube Assy
14-3:
Step 5: Rivet all Flap Hinge Brackets to associated Wing Ribs.
Step 6: Rivet the Flange Bearings and Torque Tube Support Brackets, Angle, and Spacers together prior to assembly to Rib. Used AN470AD4-5.5 instead of the AN470AD4-5 was indicated. Used AN470AD4-6.5 instead of the AN470AD4-6 was indicated when riveting the W-1029C angles. Used pneumatic squeezer for these rivets.
Step 8: Riveted the inside Flap Hing Ribs to the associated Torque Tube Support Bracket assemblies. I used traditional rivet gun and tungsten bucking bar for these rivets.
Worked from one side to the other
Bucked Rivets with shop head this side
Finished Torque Tube Support Assy
