Removed the wheels and brake shoes. Rounded the brake cams. Drilled and tapped the brake plate to accept the wheel pants. Greased the cams and wheel bearings and re-assembeled the brakes. Installed the wheels. Getting the measurements just right required installing and removing the wheels several times.
