Brief Description: Fit the carb to the intake. make adjustments.
I test fit the Aerocarb to the intake. I removed to drill open the mount on the carb that retains the mixture cable. I also made a new tube insert to lock down the fuel cable.
Opens up hole to allow the mixture cable lock.
Made a new insert to lock down the throttle cable.
