SCOTT'S WEB SITE
Date:  5-15-2007
Number of Hours:  0.25
Brief Description:  Called Zenith for OK on Line Position
Spoke with Roger today and stated that my brake lines are routed up the center channel underneath the forward fuselage. He stated that there was no problem doing it that way.
A concern was voiced that the airflow would be highest down the center of the fuselage in that area and that stones, etc might impale the lines but his opinion was that this would not be a problem.
After the call, I also noticed that the 601XL at William's hangar has a notiable bend at the center of the gear structure (Figure 1) which might cause the line passing over the gear to rupture on my installation. I will need to provide both a covering for the line as well as some slack to account for the gear pushing downward as in the photo shown.
slight bulge in gear at center on William's 601XL
