SCOTT'S WEB SITE
601 XLB Zodiac
Installing Nose Gear Bungee
Note: This tool was purchased along with another tool for drilling holes into the main gear from Kobush Welding in June 2006 (see expense log) for vendor info
Position bungee on gear
Use tool to put bungee into position
Now just tip bungee over the top support post
601 XLB Zodiac Home
1334
Brakes/Brake Lines
Control Stick
Engine & Taxi Tests
Firewall
Flight Test
Hangar
Inspection Day
Instruments
Panel
Throttle Setup
Upgrade
Wiring
