SCOTT'S WEB SITE
601 XLB Zodiac
checking angles
Made sure the baggage and spar carry thru were level and at correct angle. Installed bulkheads in correct position.
Using wood jig to check angle and level
601 XLB Zodiac Home
1334
Brakes/Brake Lines
Control Stick
Engine & Taxi Tests
Firewall
Flight Test
Hangar
Inspection Day
Instruments
Panel
Throttle Setup
Upgrade
Wiring
