Brief Description: Setting Fuse on saw horses and alignment
Bought 2 adjustable steel saw horses plus an adjustable roller type saw horse at Home Depot. Set them for the smallest height and moved the fuselage over to the saw horses in pieces. I used 2 aluminum square tubes that I purchased from a screen store for the longitudinal supports.I then reassembled the fuse so that the rear was matched again with the floor. Then reinstalled the wing spar carrythrough and the firewall.
