SCOTT'S WEB SITE
Date:  7-11-2006
Number of Hours:  3.00
Manual Reference:  6B4
Brief Description:  Cut Vertical Stiffeners, add Cable Outlet fairing
The two fuselage holes were already cut for the fairing. I had previously cut all the fairlead material so that all I had to do was dig them out of the kit. After trimming the fairing so that it would fit, I drilled the pilot holes. Ooops. It doesn't fit on the fuselage properly. Redrilled the holes and trimmed some more and now it looks good.I used the bandsaw to cut the nylon fairlead material to size and then cut the 1/8" slot into the fairlead. Ooops. The slot is on the wrong side.Well, after ordering a new set of these parts from Zenith, I proceded to install one of them correctly. Just need to make sure I make a mirror image of the one on the left side so that it installs properly.
