SCOTT'S WEB SITE
601 XLB Zodiac
Started cutouts on Instrument Panel
The instruments were cut using a 2.25 and 3.125 inch hole saw, a variable circle cutter and a unibit from 3/16 to 0.75 inch.
First cut was pretty good - Air Vent
The engine cluster worked pretty well
Almost finished
601 XLB Zodiac Home
1334
Brakes/Brake Lines
Control Stick
Engine & Taxi Tests
Firewall
Flight Test
Hangar
Inspection Day
Instruments
Panel
Throttle Setup
Upgrade
Wiring
