Brief Description: More wiring and radio installation
Installed the radio trays and started running wiring in support of the radios. I have discovered some of the harnesses could tub and chafe on the bottom of the sub-panel so I will need to resolve that issue. I went ahead and put the three radios in their respective trays to make sure I had enough room and the trays were installed in the correct location.
Now I will plan the chafing solution, pull everything out including the panel. Fix the problem and reinstall everything.
