Wiring continues with more work at the fuse panel. I attached the terminal block for the left position light and taxi light to the inside of the most outboard rib. Also the three position lights wiring has to join at some point. I attached a terminal block for attaching the three wires to the power wire from the panel. A cleaner solution than splicing multiple wires.
