Brief Description: Pressure testing the right wing
Pressure tested the rght wing today. I decided to leave the wing in the wing storage rack instead of moving it to a workbench. It was very difficult to get to the vent fitting to attach a ballon. After a few trys I decided to fabricate a small fitting to attach the ballon. You can see the small aluminum tube connected to the fuel vent. Once connected I pressurized the tank and using soapy water I checked for leaks. None. I checked five hours later, still no leaks.
