I am not happy with the way the pitot mast is installed. I have decided to take it out and re-install it. Of course, this means ordering a new mast and a new lower skin. But I won't be happy until it is right. I have also ordered a few extra fittings to connect the pitot tube lines to the pitot static system lines. The pitot static system lines are nylon while the tube has aluminum lines. You can see in image two the different lines; the blue line is for the AOA and the green line is the pitot system line.
