Finished some little projects that needed to get done. I pulled the bottom skin off the left wing to clean up after the pitot mast installation and to double check the fit. Satisified with that I ran fishing line down both black conduits. I tied a cotton ball to the end of the line and used a vacuum cleaner to suck the line through the conduit. I ran double the length required so I can sun several wires without having to re-feed the line again. After all the wires are in place I will pull it out.
Next was 'painting' some RTV around the conduit where it runs through the ribs. When the RTV dries it will help hold the conduit in place. Finally in anticipation of closing this wing I installed the bell crank for the left side aileron.
