Now that all cowling/oil door rivet holes were drilled and treated, I mated and match-drilled the lower cowl intake seals' screw holes. With that, I masked the Skybollt flanges then spraypainted the cowlings.
- Inner surfaces received Rustoleum gloss white enamal. The white will help protect the fiberglass from engine and exhaust heat, and gloss white is easier to clean (oil drips/stains, etc.).
- Outer surfaces received grey Stewart Systems EcoPrime.
