Continuing with the intersection fairings, I through-drilled the upper intersection fairings to the fuselage. I also test- and fit-mounted the nose gear intersection fairing to the wheel fairing.
Once all intersection fairings were fitted and cleco'd to the wheel fairings, I applied an epoxy/flox mixture between the intersection fairings and their wheel fairing hosts, cleco'd them in place (used Turtle Wax to protect the clecoes), then set them aside. This served to "tack" the intersection and wheel fairings together, fitted and aligned.
Drilling the main upper intersection fairings to the fuselage
Nose Gear lower intersection fairing
Intersection fairings tack-epoxied to the wheel fairings
