Brief Description: Modifying the tire fairing mounts
I modified the tire fairing mounts by expanding the radius around the brake calipers' top bolt and also grinding a cut-out to accomodate the hydraulic line's AN elbow (image 2). I also added 2 washers on each side of the spacer bushing that holds the tire fairing mount--this was necessary to get the required 1/16 inch space between the tire fairing mount and the wheel's brake disc.
