Brief Description: Installing Dynon Skyview VHF, part 3
I ran the first cables and wires from the Dynon VHF. Started with the Skyview network cable, which I ran from the VHF control panel to the pilot side network hub. I then ran the antenna cable from the VHF transceiver on the sub-panel to the copilot side floor. I installed one BNC connecter, but then learned I only had one connector.
Work stops until I get another BNC connector and hi-density DSUB pins for the connections to the PS Engineering audio panel.
