Sid & Houston Mayeux Project
Date:  1-12-2014
Number of Hours:  3.00
Manual Reference:  Spar plate covers
Brief Description:  Spar bulkhead side plate covers, part 2
I had a slow-down with the map light wiring. At first I tried insulated blade-type connecters for the two wires, but they wouldn't make the turn between the cover and aircraft side wall, so I used smaller RC model 22 AWG connecters (which match the wiring to these low-amp LED lights). This worked, and with plenty of service loop pushed in.
I had to temporarily remove the air vent bodies and headset plug brackets to get my pop rivet gun in there (I hate using the hand puller). Riveted the plates into place.
One problem to fix later: The map lights are supposed to work in conjunction with a rocker switch on each end of the panel, but these lights came on hot with the master turned on. I'll sort that out later with the VPX configuration file.
Pop-riveting the plate covers into place
Finished (both sides)
