Brief Description: Fabricate/Install fuel tank attach brackets
I installed the fuel tank attach brackets, the forward-most of 3 attachment points between the wings and the fuselage. I fabricated the mount pieces, shims, and angle brackets, then match-drilled them through the fuselage sides. After countersinking the holes, I riveted all hardware in place, but I'll bolt the brackets on later.
Pieces fabricated, cleco'd in place, holes match-drilled
Holes drilled, counter-sunk
Bracket in place...will install the attach bracket later
