Brief Description: Elevator push tubes and control column
I connected the rear and forward elevator push tubes to the bell crank and autopilot pitch servo. Then I connected the forward elevator push tube to the installed control column. Checked clearances and travel all around, particularly ensuring I had no conflicts with wiring.
All good to go.
Pushing forward elevator push tube into tunnel
Forward & Rear push tubes connected to elevator bell crank
Control Column mounted, connected to fwd push tube
