Having problems with the gap between the forward canopy frame and forward fuselage skins. Should be about 0.02 and 0.035 inches, but it's a lot wider...as much as 3/32".
Stopped to research whether this is a problem with the Van's Air Force and Van's plant folks.
UPDATE: The Vans experts all said, "Build on!" The canopy frame will change alignment many times as I add to it, so no sense in worrying about it yet.
